done mine yesterday .... all heater settings now work T: T: T: 82p is the cheapest fix yet on my van, the resistor was 216c but maplins only had lower or higher, i went for 228c, that was the next one upMine also played up only worked on the 4th setting, I'm not sure if it is the resistor pack that's playing up but you can always pop down to maplins and buy a 240C resistor for under a £1! I cut off the old resistor from the resistor pack! and replaced as you can I attached it with terminal blocks.
http://www.maplin.co.uk/thermal-fuses-470
Saved my self £30 or so....
