G
Guest
·I have a 1995 van with a slider style adjuster for the temp. It is fully hot or fully cold, but nowt in between. So I looked under the bonnet and found the cable and valve assembly. They are connected proberly, but I noticed that the cable only seems to work in the 1/4" from the hot end of the scale. In this narrow band it goes from full hot to full cold. The rest of the range is ineffective. I guess the cable has stretched?
So, how do I replace it, and how do I get the control panel off as the sliders appear to be glued onto the mechanisms?
