Wanted to fit some different lights in the back so went into B&Q for some decking lights as they run on 12v and have read on here there nice n cheap.
Had a bit of problem though.
Marked them out on the rear ceiling panel, took the panel out n drilled the holes. Popped the lights in and pushed back into place.....
To my shock there isnt enough room between the panels n the roof by about 10mm. (didn't think about checking the depth) Not to much of a problem ATM as im changing the panels, but not sure on how im going to get over the depth situation. Think im in need of some help/advice.
Thinking of packing down the ceiling to create more space above or changing the lights and putting these somewhere else in the van just to use them up I:
