Hello, does anyone ever had black smoke a problem before? My T5 is having a lot of black smokes coming from the exhaust..
I've replaced the Diesel fuel filter, Oil filter, & Air filter is still does the same thing. What should i do to fix it???? Please help!!! :*
We had this normally when we got back from a trip in Europe and found this wa cause by uk diesel have you run through the diesel in you tank or has it been ongoing thought several tanks of diesel
Unlikely to be turbo as this would give blue smoke , more than likely causes are EGR valve sticking open or coolant temp sensor reading cold and the ecu putting to much fuel in hence black smoke , sometimes tickover can increase also ,hope this helps Andy:ILU:
