I think I've worked out what part I need, it's the blue, 4 pin temp sensor, VAGCAT tells it's part number 701919369C.
The local parts store I usually use can only find it from one supplier and it's £45! Does anyone have any ideas where I can get it from for a better price?
Do you mean the sender that pushes into a plastic housing near the thermostat? My old one was blue and I was getting way high readings, I replaced it with a black green one from gsf and all seems good, although on their website it says its 2 pin but unless I can't see properly its actually 4 pin
