morning
i need a bit of help !
anyone got one of these in there van
note that it dont have the switch like most ,and on the rear it says 30100186 part number and on the circuit board inside says eb147
what in after is a wiring diagram or if possible some one to pop the lid of and note what clour wire goes to what terminal number
ive googled 30100186 and cant find it
cheers in advance
look for the actual heater wiring diagram and the controls are shown in that,you may have to look a few of the heaters to find the control you have and cross refernce it back to the heater you have
yeah ive got heater manual and the stat/modulator is not listed in it the part number dont seem to exist
ive rung pf jones a northern dealer and he sez its an odd ball thats why i put the post up to see if anyone had one
If you take the cover off is there 7 terminals? I think both the 30100186 (with no on/off switch) and the 30100154 (with the on/off rocker switch) are wired the same.
What heater you running? D2?
