I'm in france and the van can never find reverse, I have just paid a lot of money for all new bits done at VW... All the gear linkage is new..
I did a bit of investigating and the plastic shroud that's bolted in from underneath seems to me to be on backwards!!!! This means when trying to get it in reverse it hits the shroud and 5th moves way too far! Not as easy as just spinning it round as it locates the gear stick mount underneath!
Could anyone lift up the rubber gaiter around gear stick and take picture of the shroud?? Will let me know for sure if this is case.
Think all the movement in the wrong directions is causing more damage than good.
I'll try post a pic if I work out how from the french services!
Discussion Starter · #2 ·
Can't post a picture but as you look at it from the back of van, the low side is on the right.
There is a lip on the left hand side of the stick which is obviously meant to fit under the lip that's on the shroud.... There on opposite sides aswell
