hi all
Recently had a engine ignition switch fault, once replaced immobiliser now dying iafter 1 second engine start.
Took into vw specialist they replaced reader coil around key barrel but no joy.they gave up
So purchased full vagcom and have some results that I was not expecting help anyone?
No keys adpt 0
Reader coil status 0
Key status 1
Variable code auth 0
Learning time 0.00
Number of keys 1
Number of keys actual 0
Key matching status 0011
Ideas folks?
I have 3 keys with the same transponder same results
Other errors from vagcom
Engine blocked by immobiliser
Please check dtc memory of interment cluster
Immobiliser pickup coil
Bare in mind coil changed apparently what do you think people?
