HI. 2000 1.9 800 special.
I have changed the battery, strater motor and ignition switch, but the thing will not even turn over :*, it just clicks once as if the battery is dead.
This i should add, does not happen all the time, and if you push start it, it is fine until the next time it does it. This has happened on several occasions, and can range from two weeks, to two days etc so not easy to trace. Been into a garage, and they (as expected) couldn't find the answer.
ANY SUGGESTIONS?
I have had this once before too.... was told it might be an earthing problem?
