1 - 20 of 22 Posts
2003 V6 (not VR6)
I need to know what some of these things are under the bonnet, so I know what is leaking etc. I can't also seem to find the distributor:D
this is leaking the pic is shot up from under the passengers side (RHD) front wheel, it is above the starter motor and ignition coil (bottom left of photo)
this is a black plastic thing in the front with an air filter darlek thing on the front
this is either leaking or being leaked on, looks like a big tub, on the pass side behind the starter
these are right and left shot of the engine, I cant find anything that looks like a distributor
If I can just get this car working properly I'm sure I can enjoy it, but having all these troubles only 1 month after purchase I am wearing thin, any help would be appreciated.
Oz
I am registered there and I can not find my model, AMV V6 2.8lt. they list off 7XX numbers and mine is none of them.. VIN WV2ZZ27023H007XXX
Oz
2003 >> 70-3-250 000 7d., 70.
2003 7h-3-000 001 >> 7ha, 7hb, 7hc, 7hh, 7hj, 7hm
2003 7j-3-000 001 >> 7jd, 7je, 7jl
Is that the VIN of your car? Shouldnt be XXX like that.
PM me the complete VIN and i'll look into it, i work at a VW dealership.
Discussion Starter #11
15A 021905106
ignition transformer
so this is VAGCAT they have a dizzy in the pucm but no nymber, does this mean I haven;t hot one?? Its location is plain, but it aint there
lets have the full vin number and as much info as possible PM it if you want. 2003 is the most cmplex year.....
a distributor is not required on all engines the electronics do all that and a single coil aint needed. those 6 things in the third picture could be coils...
TBH your pics are a bit to close up to get a feel for where we are in the engine inmost pics.
Discussion Starter #16
Wiki foesnt even list it then
Petrol engines
Model Engine ID code Engine configuration Engine displacement DIN rated motive power @ rpm Torque @ rpm Years
1.8 PD inline-4 SOHC 8v 1,781 cc (108.7 cu in) 67 PS (49 kW; 66 bhp) @ 4,000 140 N·m (103 lbf·ft) @ 2,200 1990–1992
2.0 AAC inline-4 SOHC 8v 1,968 cc (120.1 cu in) 84 PS (62 kW; 83 bhp) @ 4,300 159 N·m (117 lbf·ft) @ 2,200 1990–2003
2.5 AAF; ACU inline-5 SOHC 10v 2,461 cc (150.2 cu in) 110 PS (81 kW; 108 bhp) @ 4,500 190 N·m (140 lbf·ft) @ 2,200 1990–1997
2.5 AET; APL; AVT inline-5 SOHC 10v 2,461 cc (150.2 cu in) 115 PS (85 kW; 113 bhp) @ 4,500 200 N·m (148 lbf·ft) @ 2,200 1997–2003
2.8 VR6 AES VR6 DOHC 12v 2,792 cc (170.4 cu in) 140 PS (103 kW; 138 bhp) @ 4,500 240 N·m (177 lbf·ft) @ 3,000 1996–2000
2.8 V6 AMV, AXK VR6 DOHC 24v 2,792 cc (170.4 cu in) 204 PS (150 kW; 201 bhp) @ 6,200 245 N·m (181 lbf·ft) @ 2,500 2000–2003
Petrol engines
what does it say on the vesicle docs?
lets have some info.
Discussion Starter #20
All the info I have on the docs
VIN (sent in PM)
Z218 19-2-0479 767 DU assume this is chassis No.
Engine Type AMV 002684
transmission EGJ
thats all the info I have from the fuse box cover
1 - 20 of 22 Posts
