Hi i have just had the 2 & the 1 seats fitted to my panel van. I supplied the everything which i brought with the seats the question i have is when you come to tighten the C pillar bolt for the seat belts it stops the belt guide at the top from freely moving. It would appear the bolt has a shoulder on it that doesn't seem long enough so when you tighten it up its not bottoming out where it should & stopping the seat belt runner from moving freely the seats & belts came out of a shuttle not sure what to do any ideas would be very much appreciated if you can make sense of my description cheer Koopz
Most fail to add the washer that should go on the top bolt, that's the reason the top bolt does up too tight and binds the belt from pivoting , a few pence from VW.
