I've picked up some rear seats on ebay (assume they are genuine they have inca fabric) to convert my lwb into a crew cab, a twin and a single. They didn't come with any fixings or rails so I need some advice about where I can get the bolts or rails I need. I think they are quick release as there are hooks on the feet. Any help would be very much appreciated!!!
Have a look at the feet of the units. Most seats for T4 and T5 are fitted using mushroom bolts. The are (funnily enough) mushroom shaped bolts that are placed on floor bolted through floor. Under the van you have captive nuts (spreader plates basically metal with a nut welded into it) that fit exactly in the chassis rail underneath. They can be fitted loose underneath or pop rivetted and welded to rail for security. The bolts are then tightened up and the seats fitted forward of bolt and then dragged backwards clicking into place. To release lift lever up and kick the legs of the seats to free them.
Good luck!
