Hi, advice required, what are the best looking/comfortable seats to replace the original front seats with ? I have a T4 with a single and double at the moment but looking to replace with 2 single front seats from the car breakers, someone said rover 400as they are plush etc or saab, would any car seat fit as long as the base is changed to suit ? I saw a thread on hee the other day where the owner had new single base's made up to suit the seat and runners from a ford, would this be easy to do considering there is only 4 nuts on each base to remove and would this be to expensive ? thanks for your help.
saabs are dead easy as the seats have flat runners.neo brothers are in enfield who are saab breakers,then all you need is a single base which i have so hope that helps T:
anything with flat bases
saab and some rover , some audi are good
also seen merk- look a bit more fiddly
I thought all fix to a flat base ? Do you mean the runners ? so if I was to get 2 front seats keep the runners on then these secure to the base.
