Good Morning and hope you had a merry xmas :)
Some help please, I have a 96 2.5 tdi LHD Westie and am having trouble finding the gears. If I ride the clutch and move the gear lever very slowly they will go in, otherwise they graunch. What I have to find out before the mechanic will book it in, is if it is cable or hydraulic clutch. I have searched on the internet and altho T4´s are usually hydraulic, apparently some LHD´s are cable operated. I have looked but cant see any pointers under the bonnet and have a belly pan so cant see any thing underneath.
Any help much appreciated,
right hand drive vans have issues with the pedal box cracking and causing similar issues to your having,check your pedal box for cracking around the clutch slave cylinder :*
Cheers,
thanks for advice, i can pass it on to the mechanic and give him a head start on what to look for, tho I am a bit sad as is now going to be more expensive repair!
thanks again :)
