Hi all, how do you remove the RHS headlight from a T4? I can see the two 8mm bolts at the top, the lower adjusting screw plastic retaining thing has give up the ghost.
Cheers John
if you look on the lower part of the grill you will see 2 screws there actualy set back int between the vents
then the sides are held in with 2 clips each side they just pull of those .
