Hi all, in the process of fitting my pop top and wondered if the side support channels which are riveted along the top need riveting/fixing along the bottom edge aswell, if any knows:*
Apart from that all going swimmingly, cut hole today, fixed the front and rear support frames, did all the wiring, cut side supports to size and even tried the bed inT: Touch wood, all going hunky dory so farA:
Jay
Many thanksT:
Took me a while to measure it all out, spoke to Bill and he gave me some pointers. Cutting was the easy part. Not looking forward to fixing the tent but take it slow should be okI:
Have any of you had problems with the back being too high? Fitted the roof & hinges and there is a 20mm gap at the rear, 8mm with seal on:*
I haven't had chance to have a proper look yet as I got the roof on late this afternoon so will have a proper look over the weekend, seems like there is some up and down adjustment on the hinges?
