when i picked up my T4 as an unfinished project, it came with enough MVM BLACK carpet to finish of the interior.
BUT... if and when i do an other one i would go for gray carpet.. Reason being.. the black makes the inside very dark, but more so.. it shows up every little speck of dust/ bits.. etc!!
don't think the gray would do quite as much..T:
if you look at this picture,you can see all the little bits of.. well bits and dust. etc..:(
door covered OK mind
Had exactly the same 'debate' with my mrs,I wanted black she thought too dark:*
So we ended up with anthracite 'cos it's got more depth apparently:*
TBH she was right,all black may be a bit flat plus with anthracite it hides a lot of dust/bits etc.Especially now we've got a dog,so the mrs was right!Still not told her that tho'...
Wow really neat, how do you finish the edges on the door cards? I was thinking of spraying them but now I might carpet them, which is the best carpet to use?
hi
i want to line my interior as well..got original caravelle intetrior,was gonna replace it with ply,but see dubninja did a fantastc job lining pretty much everything A:
just bought myself some hi temp adhesive- http://www.ebay.co.uk/itm/390380883201?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
and lining-http://www.ebay.co.uk/itm/390380883201?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
hope this stuff is ok??
how do i finish edges and and do all the curves??also bet there is a tip or few to hear before ruining everything:)
thank You :)
