T4 1992 1.9D
Attempting to change my water pump, drained the system, taken the Alternator off and bottom 2 bolts of water pump/alternator bracket, how the hell do you get to the top 2 bolts?! only managed to loosen the one on the right with a ring spanner but am now stuck!
if its like the 2.5,the other 2 bolts are behind the cover for cambelt,which has to come off?
can't remember the size but i'm pretty sure i had to buy a deep socket to do the awkward ones think a short extention is needed too. they are a right faff to get to.
You can't get a socket on them, no room, the left bolt is behind the timing belt cover, not sure if the cover will just move around a little to get to it but didnt wanna attempt that if I can't do the right one which is not behind the timing belt.
T4 1992 1.9D
How did you get on with the above I need to do the same I have t4 1994 1.9D same design as yours I think. I can,t work out how to remove the drive belt to get the ALternator off any help
T4 1992 1.9D
Take the alternator bracket off the front of the engine, then undo the 3 studs, pump and housing will then lift away from the block, remember to replace the o-ring when refitting.
