Just wondering if anyone has used Lotus white/ blue mica paint?
We are having trouble getting it to cover properly to give the effect of the blue showing . :eek: Has anyone on here used this paint?
Thanks :D
Sian :D
I would advise spraying a test panel first,you may find you wont see the effect until the lacquer is applied.
If it is a 3 stage pearl you need to apply a solid colour ground coat,which is on top of a shaded primer,one which is easy to cover,so if your spraying white,you will need a light grey primer,then a white base,then the base coat with the effects in,finally lacquer.
