Got in the van the other day afer work and drove about 5 miles. Stopped off to have haircut and reversed out of parking spot and van crunched into reverse. Didn't think much about it because I thought matbe i didn't have the clutch down far enough..
Drove another couple of miles and as i approached a junction it wouldn't go from 4th to 3rd, so i tried 2nd and it went in.
Got to next junction and stopped, couldn't find any gear at all. When i eventually did the van wanted to move but my foot was on the clutch. I managed to get the van home but struggled with gears by then. When the van is switched off the gear stick moves into all gears no probs.
Is this a clutch problem or a gear box problem do you think and if so how hard to fix etc
Rich
Meithered to death
Clutch has gone bad,maybe the bearing has worn through the spring so it wont disengage
Not a gearbox problem then?
Is a clutch easy to fit it does it only need a bearing etc?? Not a mechanic at all
Rich
