Problem with the high beam on my converted T5.1. The nearside high beam is always on and so is the dash warning light for high beam. I pulled the fuse for this lamp which sorted one problem out so now the dash high beam warning light only comes on when I flick the stalk but as the fuse is out only the the offside high beam comes on. However even with the fuse out the nearside high beam is still on when the headlights are on! So to sort this out I pulled the high beam feed wire (white) off the back of the headlight bulb so now only dipped beam works on the nearside (which isn't a big problem until the MOT). With the high beam feed not connected and the fuse in, the high beam warning light stays on. I thought that this might be related to the headlights being removed for a recent respray but the main connector to headlights seems ok and when tested with a multimeter the pin which feeds the high beam is live when the headlights are on.
The stalk also appears to be working fine as the dipped beam and high beam work fine for the offside headlight.
This has me stumped but before I send it off for an auto-electrician to figure it out wondered if any of you guys would have a clue.
