Just wondered if anyone had any experience of the horn and hazard lights coming on when the ignition is turned on, the van is a 2008 T5. I've pulled the horn fuse and the van starts no problem and the hazard lights go off but the left indicator stays on.
I've read it could be either be corroded wires under the drivers seat or a voltage regulator (J519) behind the dash, I've checked the wires and they appear to be ok, not sure how I would check the J519 or if something else could be causing this.
Any advice appreciated.
Special Rapporteur
Does it have an alarm fitted? Some are wired to hazards and/or horn, for audible and visible outputs.
It does have an alarm, which seems as though its working ok. When the horn sounds its a continuous sound and not intermittent like when in alarm.
