Evening all. Horns just died. 1997 t4. Got an air horn fitted which I know is good but have an aftermarket steering wheel and boss. Removed wheel yesterday and found one terminal of horn switch wired to steering column and the other terminal has a wire leading to nothing. Can anyone tell me how the switch Should be wired in please. ❤
176330
Full of Cr*p....
Simple thing....with air-horn(s) YOU NEED A 30 AMP RELAY anyway!!!! (otherwise you just burn the contacts out on the wheel!!"
The contact on the "proper" wheel is a simple contact to "earth" (negative).
Should be NO wires in the actual steering wheel.....just the ring/slider contact.
"Pretty" van, shite headlights, and wondering about the ratings of those wheels you have on it. :rolleyes:
Whilst I'm posting/digging at you....those trims on the wheel arches are well known as to cover up ROT...and to make it WORSE!!!
I bought a set 7 years ago....but after reading on here, they still sit in my garage!
