I don't know what else it could be called. It's the ring on the back of a standard steering wheel. Can these be bought and replaced or will i have to find the whole new centre of the wheel piece? The part where the wire connects to is snapped and in too much of a piggy place to solder (or i'm too lazy) :*
From what I ahve seen U will need to replace it. Can`t see it in the parts list.
U write "center part of wheel"... U do meant the steering wheel as whole :*
Time to go fancy perhaps?
The copper ring is not sold separately you have to buy the ring and plastic housing that slot into the middle of the steering wheel - £8.10 incl VAT is what I think I pad a few months back from a VW Dealership - Will try to dig out the part Nr for you.
That would be cool as I can`t seem to get those that I have had in my steering wheels off properly.
Dunno if there is a difference with & without Airbag..... I looked at both tbh, allthough older type (upto mid 90`s)
I fitted a Airbag wheel to a non-Airbag recently... Did work OK in the end T: Was afraid I had to mess about with the ring at 1.st
