Ok so when i got my van it was running 18psi boost due to a duff n75. ran like this for about 8weeks with no problems except ecu putting her into limp above 3k in 5th.
Then i got round to replacing the n75, and she ran at about 12psi for about 4weeks, again with no problems whatsoever.
I had my van remapped on friday by a well known company ( i wont name names until this is all cleared up) started off at 122.3 bhp, came out at 149.7bhp. boost was at 12-14psi. One thing to note is that the wastegate actuator had to be adjusted to hold boost, but yet it never had a problem holding boost when it was at 18psi...?
Van didnt really feel much different except in 3rd slightly pokier, and 5th where the extra torque was immediately apparent. could go from 50mph to 80mph without breaking a sweat, even uphill. did notice a lot more smoke in the rear view, but put this down to extra fuelling( couldnt tell colour as it was past dark by then).
so did a fair old drive home and let turbo cool down before switching van off.
Went out following morning and started her up and she was lethargic and missfiring. let her run for about 20-30secs before prodding the throttle wherby she blew out blue and black smoke in equal amounts and misfired like crazy. Drove van to end of my road and back (short road) and parked her up having noted no boost ( guage was actually sucking into vacuum instead of boost pressure) and no turbo whistle.
Removed i/c and pipework to discover the pipes and turbo were FULL of oil.
So the turbo has died.
i really really dont see why the turbo would just suddenly die when the boost levels were LESS than it was running previously with no issues. and i also cant understand why the actuator needed adjusting to hold less boost than it was previously managing to hold with no problem at all?
I have had no warnings of a turbo on the way out, no blue smoke or oil consumption, no change in noise, nothing, so i am really struggling to figure this one out!
If anyone can shed any light on this, or has any ideas/theories/similar experiences that would be great because to say i am a bit miffed is putting it lightly!
I will not be getting lairy with the company involved, whats happened has happened and thats that, but i would really like a reason not to be able to blame them for this, because whichever way i look at it it was fine before the map, even running far higher boost pressure, and yet one journey after the map and its dead. its a bit of a big coincedence :*
