Hello,
I'm gonna buy a T5 and convert it to a Camper myself. Fitting the units, bed etc I will manage no problem but I'm not sure about wiring for the fridge, lights etc and the 240 hook up. How hard is it?
Any advice appreciated.
Cheers,
Will
jabby fingered, worn nubbed, ginger ninja
If youre using a voltage sensitive relay then it's simple
You wire from the starter battery through online fuses to the vsr to more online fuses and your leisure battery, from you leisure battery to your fuse board then on to your circuits.
As the meerkats say
SchimplesT:
Edit:
If you have a hunt jurasik did a brilliant wiring guide that is easy to follow
Hello,
Cheers,
Will
To be honest, as long as you are prepared to ask, the electrics will be a lot easier than building the conversion. Understandably a bit more daunting if you havent done them before, but if you can follow basic guidance and are prepeared to buy the right equipment then they shouldnt be to much of a nightmare.
