Hi my t4 is loosing water Badley through the rad.
I wanna try radweld before I have to spend big but want to do it properly. So I need to flush the rad first but I have no idea how to do it.
What is the correct antifreeze mix also.
Cheers people your help is appreciated as i don't know what I'm doing!
Marley
to flush mine, I took it off the van, in the house in the bathtube and filled it with hot water and then empty it few times, until the water coming out was as clean as the water going in.
tip....do it when your wife's not at home....
I put 2 litres of antifreeze, rest water.
But I never go on the continent in the winter.......
If you want to stand freezing winters on the continent (up to -40 degrees), then more antifreeze is required.
Usually it says on the antifreeze bottle how much you need to mix.
