hI all
Just wondered how you adjust/set up the rev's on my 1.9td, also were should the clip be on the throttle cable I have stupidly messed with the positioning of this clip to try and sort the revs and not sure were it should be, also I've noticed al ittle plastic switch in front of the pump not connected to anything just hanging in mid air.
Many Thanks
Astley
Think thereis an adjuster screw on the throttle stop on the pump for the revs.
The clips goes on the right hand side of the bracket(as you look down on it from above) but you need to take the slack out of the cable sleeve first.
Just pull the cable sleeve to the right till all the slack is gone then pop the clip on.
The little switch is for the egr valve. If it's unplugged, means that. The egr has been discontinued and should have blanked of. Which is fine.
If the cable is at its limit just unscrew the stop under the accelerator pedal.Till you get a new cable.About £50.
