i want something to bring my steels out a bit they are sat too far inside the arch
are spacers, legal or any good? an safe
are banded wheels safe?
i am using for heavy loads and off road
Its about time I showed up
Can of worms there fella I:
The following is just my opinion ;)
Yes you can use spacers if your wheels are sat on the hub still or you can get hubcentric spacers.. Anything over 6mm in spacers needs to be hubcentric imo.. Dont forget you will also need longer wheel bolts.. They are safe if used correctly T:
Banded wheels :* I'm on bandys and Yes lets hope they are bloomin safe LOL:
Both the above are as safe as running cr__py alloys on rubber band tyres fella :cool:
Hubcentric spacers bolt to your hub and have a lip that your wheel center sits on so all the weight of the wheels/van isnt only on your wheel bolts..
Spacers EBay mate or Brickwerks do some i think.
Bandys check out bandedsteels.com this isnt a cheap option though ;)
