241 - 260 of 268 Posts
That looks awesome (y)
I did think the other day while tinkering in the van while the sun was shining, if I played sounds of some seagulls and the lapping of the sea on the beach, I could almost feel like I'm at the seaside :cool:
Discussion Starter · #242 ·
Slept in van last night for this first time in over a year. Think last time I slept in it was about 4 hours after our lad was born. Went and crashed out right outside the hospital entrance. That was probably the last good sleep I got for a while!
Watched the NASA/SpaceX Demo 2 launch, bit off ISS and dragon hunting then slept with the doors open all night. Was really mild!
Sadly after a full night charging the starter battery it was still not holding a great charge this morning. I figured it was probably 7 years old as the original factory battery and the lockdown gradual voltage depletion had put an old battery off the edge, never to recover. Never mind.
So I went and paid far more than I should have for a new, bigger battery from Halfords today. Still wanna do the votronic battery to battery charger to trickle charge the starter battery from the leisure charging sources but as of yet, they still seem to be out of stock absolutely everywhere. Hopefully I can find one soon to keep this new battery optimal.
I had similar problems with my battery, talking to the mechanic he said it was ok for when the van was a van, but since adding in a better stereo, led lights front and rear etc etc it was more of a drain so I like you opted for a much bigger one and been happy days ever since (y)
Discussion Starter · #244 ·
So took me a while to actually find one anywhere but today I installed my Votronic 3065 12v battery to battery charger for keeping the starter battery topped up.
Added a 5A fuse on both the leisure battery and the starter battery positive feeds to the unit under the passenger seat and screwed in it. Pretty much it.
So now if the solar or mains is charging the leisure battery, then the leisure battery is also trickle charging the starter battery at 3A max. Which is perfectly sufficient to keep on top of the tiny drain of my tracker during periods of low use.
Like during pandemics
Good little solution for 25 quid though. Happy.
Great thread. I'm pretty sure that lockdown killed off my alternator. Lesson learnt - popping out and starting the van more often now with the hope of it not happening again!
Discussion Starter · #246 ·
3 years after purchasing the van, we finally bit the bullet and got some new wheels. And now they are on, even the mrs has realised the old ones let the van down a bit.
For the first time since I converted the van it actually feels kinda finished!
20” Axe CS Lite rims in Hyper Black with Continental CrossContact ATR tyres (275/40/20). All properly load rated.
Speedo reading within a margin of about 1% vs GPS speed so happy with that.
Just need to paint my rusty towbar now...
cheers guys. yeah, our wallet is also taking a battering.
After putting the conversion off until i finished other projects, I finally got bored in a beach car park in early January and got in the back with a screwdriver and started removing panels. We had discussed whether or not to get a pop top during the previous three months and in the week before had finally decided not to do it on the grounds of we couldn't really justify the spend. No kids mind so not an issue (yet).
With that pretty big and expensive decision shelved, I saw no reason to not get cracking. So after the beach car park i drove home ripped out the carpet lining, what little insulation that was dotted around and removed the headlining. At this point the conversion was on. I then took another day to remove the floor in the back and clean off all the glue residue using white spirit, quite a few rags and a scouring pad.
I am about to embark on this. I have a furry van where old carpet pulled off. Its a mess. Any advice on best method to remove this and glue would be appreciated. Thanks mate
Discussion Starter · #250 ·
White spirit and non scratch kitchen sponges with the white scouring pad.
That and a lot of sweat
Like many others I am just about to start a conversion. I have done a couple previously which looked OK but didn't have much in the way of electrics and had only basic insulation. I would like a more professional conversion like yours this time as I shall be buying a more expensive van. Your thread will be an excellent guide to the order of things and likely problems, so thank you very much. Have you calculated the approximate spend yet?
Discussion Starter · #254 ·
Unfortunately I am aware to the penny how much has been spent on the van.
I only look at the spreadsheet when I really really have to.
Discussion Starter · #255 ·
Looks loads better on the new wheels mate (y)
I was thinking the exact same thing when I read his post
We don't tend to work this out, we just keep on spending and enjoying
Cheers mate!
She is looking a bit tastier. Although I don’t seem to be so keen to get in the hedge on Cornish lanes now to let others past. Realised I’m now driving like a tourist.
You have a spreadsheet! Are you insane, that could really negatively affect how much money you spend in the future 🤣
Cheers mate!
I know that feeling, when I bought mine I felt like I was driving a double decker bus 😖
Discussion Starter · #257 ·
I'm thinking about selling the van and Vango awning detailed in this thread in the coming month or so if anyone is interested.
Mainly because I've come to the very slow conclusion over the past 6 months that I need something larger.
It's a sellers market currently, priced right and this won't hang around long at all.
Been through this thread and loved it all, all the detail you've gone into with getting it to how it is now is incredible, I'm sure it'll be hard to let go.
What do you have in mind to go with next?
Only thing I have in mind is a Crafter!
Your van will fetch a nice sum in the current market, definitely won't have a hard time selling.
Good luck if you do go to sell it on, I guess you can have round 2 with converting another van😜
