Hi guys, right I know that T4s are notorious for being slow right! But I'm just wondering whether if I have a problem with my 1.9 :confused:1996 caravelle. Going through the gears theirs virtually no power whatsoever. it's quite embarrassing how slow it is.
1.9td's aren't slow - they are just "steady", 1.9's just more so :D
if excessive, check fuel is getting through ok - we had it when we got ours, was a blocked fuel filter. ok for a few miles & then very little power
GL
Re: How slow!!! ��
Try changing the throttle cable. They seize up with age and really affect them. T:
As it has been said above, change the throttle cable, they have a damper in the middle of the cabe which seizes an stops full throttle potential. It is 99.5% likely to vastly impove things
