How to activate multifunction display on a T5.1 with lowline screen?
55K views 57 replies 23 participants last post by  C11RGD
I have done this and I can't get the MFD to work I have done all the coding and still the lowline display.
I have a MFSW which I have coded and is working with the radio (left hand buttons) but still no Midline display and no Right hand buttons???
Can anyone help???
Yes I have coded both the multifuction display in Instruments 17 and the multifuction steering wheel in Central Electrics 09.
I will check again the repair wires but sure there are correct!
Horn working..... lights on MFSW button light when lights are put on...... no airbag lights or fault codes.
I have the wiring harness which is a black multi plug to the side of the steering wheel and this is connected as at first the horn wasn't working and found that the connector was push in correctly.... but is now.
The left hand buttons are working with the radio which if there was a fault with the wiring or connection wouldn't work????
I have fitted cruise control which is working fine and have no button on the end of wiper stalk.
BUT STILL NO MFD!?"?":*
I did have those 3x wires connected from the stalk to the instruments and coded but still have the same response no MFD. Then someone told me if I had a MFSW I didn't. Need those wires so I have removed the 3x to the clocks but had no response after coding again?
