Hi
This might be an odd question to some of you but Im having real difficulties screwing the panel to the sliding door. All my other panels are connected to the van by drilling holes in the metal and screwing through the panel and then putting a nice silver cap on the head of the screw.
But, the sliding door seems to be made from granite. I've broken so many drill bits. I've tried drilling anywhere across the centre brace, and the left left corner from inside the van. I've only managed to connect with two screws which means the panel flaps and i cant open the door form the outside!
So where have you guys drilled holes?
Yeah i used the original holes for the headlining boards, but all the other panels are done with screws and caps so I cant change now !!
