I am looking on eBay to buy some 17” alloys for my t5 Cali.
Is there any way of determining the wheels load rating and whether they are genuine van wheels?
I think they have a code on the rim such as 7.5Jx17H2 but I can’t see that this relates to the wheels load rating.
Just trying to avoid buying some car alloys for my van but doesn’t seem an easy way to work it all out!
Rule of thumb is that most if them aren’t, so it is better to buy some genuine T5 ones that are easily distinguished as T5. The most common 17” wheels that are currently being taken off new T5s are Devonport. If you are searching ebay, be aware almost everyone calls them Davenport..don’t ask me why. You should be able to pick up a new set of 4 for £500 complete with tyres (which would cost £400-£500 alone). They look like this:
Thanks very much for the replies.
Seems it’s difficult to work out which are genuine vw van wheels, load rating only seems to be printed on after market wheels.
Which just leaves wheel design to go on. So I can check the Davenports against the image above - thanks.
Do you reckon the below photo show vw van 16” Claytons?
Definitely got the correct tyres for a van, check the inside and the VW info should be there. Also, the stud diameter should be 5 x 120 - a similar alloy for Golfs etc has 5 x 112 stud diameter 👍🏻
Ok, nearly there, I’ve found some 16” Clayton with near delivery miles that look good, issue is they don’t come with any wheel bolts.
I’m downsizing from 20” wheels that came with the van when I bought it ( I want to see what the difference in ride is like) - I think they are Riva 20 so the wheel bolts are different?
So, last question - what size are 2015 (64 plate) vw Cali wheel bolts and where to get some?
It looks like there are some wheel bolts on eBay that came of a t6 - looks like 19mm bolts, do we reckon that is the correct fit for vw Cali with Clayton wheels?
They're factory fitted to T6 T32 you shouldn't have any concerns
Related Threads
VW T4 Forum - VW T5 Forum
3.5M posts
221.6K members
Since 2007
