Having struggled to do this yesterday, this might be of help to someone else.
1. Remove the grab handle from the A pillar on the passenger side. The cover of the handle comes off if you pries it with a flat blade screw driver. There are 2 hex bolts to unscrew.
2. Remove the dashboard speaker cover near the windscreen. Again this pops off carefully with a screwdriver.
3. Remove the A pillar cover. Start at the top and carefully pull away until the plastic holding clips pop out. There should be 3.
4. Remove the glove box. There are 7 hex screws to undo. 1 at the back inside. 3 on the base near the front under little covers and 2 to each side. 2 of them have rubber rings around where the lid closes. Once you remove all 7, the glove box pulls out.
5. Remove the radio set using the manufactures keys.
You will now have exposed all you need to.
Fit the windscreen DAB antenna or the outside magnetic one according the manufactures instructions. Feed the wire down the A pillar and through the dash making sure it wont get trapped in the heater controls or glove box re-assembly.
6. Replace items 1-5 in reverse order.
Should be quite simple.
No need to worry about the passenger airbag when you remove the glove box. Just don't go digging about inside the dash too much.
