Hi all this may be a easy question but I'm struggling to find a way to get a wire in to the engine bay fuse box :*
I'm trying to connect up my drls With the add a fuse kit I've got in to the fuse box but can't get a wire into there from underneath it's all contained
I've found where most wires go in at the bottom well I can feel it not see it think I would struggle to get a wire in:confused:
Is this the only way in if so how or is there better way.
Tony
I would buy a rubber grommet and drill the box to suit the grommet. Could come in handy in the future for any other future mods as well. That's what the instructions for my retrofit cruise said to do anyway and the kit came with a grommet.
Yeah good idea think that will be best bet will go get some grommets tomoro
Saves mucking about what's already there
Lhs of bulk head is a plate with 2 screws remove and behind is a large hole with grommet going into dash area then what I did was drill the plate with 20mm cutter and fit another grommet
