SEE MY LAST POST FOR HOW TO TEST AND REPLACE
Hi, I’ve got an N108 short to ground fault that I’m trying to solve.
Fault code: 17660 - P1252 (N108) commencement of injection valve : open short to ground.
I’ve tested the wiring back to the ECU and it’s ok. So I need to test if the valve is duff.
I’ve read that the resistance on the N108 should be around 15ohms.
I’ve unplugged the ten pin multiplug below to the front of the 2.5tdi AJT engine and traced the two wires from the N108 valve to pin 9 and 10.
Should the resistance across these pins be about 15ohms?
thanks!
thanks!
