Having had the cable from the front left abs/wear indicators jointed out so many times, there is no longer anything left to connect to. So had to order the full wiring harness but looking at the end it seems to either be a solder connection or a push-pin.
The connection seems to be under the battery compartment so without diving straight in and potentially damaging anything. Thought I would ask does anyone have any instructions how to get access to this electrical connection area?
Many thanks in advance
Special Rapporteur
I confess I've never had to do the job, but I can't think of any reason why the cable should go into the E-box (under the battery). It seems reasonable to assume that it connects to the ABS controller, which is to the left of the battery, just behind the fuel filter (on a typical facelift - you don't say what model you have, but the pre-facelift should be similar).
Hi
Many thanks for reply, apologies its a 2005 1.9D
There are two plugs on this lead, one goes to the abs warning and the other the brake pad wear indicator. Two into one cable. Do you think both will be accessible without major strip down?
2004 T5 2.5 174
I might be wrong about this but I seem to remember seeing on a wiring diagram that the ABS connection does go via the E box. I remember a thread where I looked it up for someone and I eventually found that the confusion in that case arose because of the wiring colours. I can't remember exactly now but it was to do with the difference between faded purple and pink!
Either way, I think you will be doing some dismantling to replace the ABS/Brake pad sensor loom. I don't think it will be too scary though.
Many thanks for this, something else to look out for! However noticed no mention of having any problems getting to the wires, so that in itself is a promising start for me.:)
2004 T5 2.5 174
I don't think it should be too bad. You will have to undo the loom wrapping up to the pump though. The pump connection has a slide-out section to release it.
