Has anyone done the hub mod on fk's? From what I can see the body of the struts get thinner further up so I could possibly only drop it through 20mm which is fine but It then makes it a little more difficult to fabricate a sleeve up for a failsafe. Does anyone bother with a failsafe sleeve? Or is it safe enough to clamp back up again?
Administrator
I think you will find people are using a sleeve. When I fitted mine it didn't look like I had anything to play with so didn't bother it's the hub mod in the end I just wound everything down to the lowest setting
