1 - 10 of 10 Posts
The last three times I have been refilling with diesel I have opened the filler cap and have a massive amount of air rush out with fuel as well, I have to undo the cap like that of a fizzy drink bottle to slowly let the pressure out.
I always keep the tank at least 3/4 full.
Any ideas? Its on my 2.5 T5 AXD 2004
It could just be the fuel foaming up as it sloshes about - most supermarket & some other fuels do not have an anti-foaming agent, so it may just be a combination of the fuel you are using & never letting it get below 3/4 tankful.
I have also tried leaving the van overnight and opening the cap the next day and it is still holding a huge amount of pressure.
I also don't use supermarket fuels, Do our tanks have a breather setup?
thought fuel tanks did not have breathers these days were connected to engine via a charcoal cannister or other means so vacuum on undoing cap is not unusual not sure about this thou
Originally Posted by Danh940
If you take the plastic off around the filler neck (just the one screw in the top left corner that the cap is normally attached to) then I think your breather is behind that!
Think this is a breather to aid filling tank quicker not sure about this either
1 - 10 of 10 Posts
