Hi
Am fitting some j&r cv joints and the inner one comes with two covers , one is the usuall one that the boot attaches to the other it just a cap .... Is the other one just a cap for transit or is it fitted to the cv joint between the cv joint and gear box ? ... Ill take a few pics
Any one fitted a j&r ???
Ps there was no second cover on the one I removed so logic says not to fit but as they are not oem I was thinking possibly they needed to be fitted to retain the grease as there is no recess for the gasket as the old vw one had
Cheers people
Discussion Starter #2
You can see the cover on the pic , it fits snug into the gear box flange ...
Just thought I would update this in case someone it helps someone else,
I phoned j&r cv joint and they said if the van had the caps the they are to be fitted if the ones you take off don't have them then don't fit them ..... Simples
