Having spent out on a New DPF a replacement Turbo ,dpf temp sensors ,injector seals ,then to find on vcds the injector 4 is overfueling
Purchased a brand new vw injector and loom fitted it today again with new streach bolts etc etc
Started it up and it smokes more than before ! SO I GIVE UP spent a small fortune oh and its just had a new DMF and driveshaft !!
STUFF IT :(
246k and og problem was the turbo failing ,contaminating the dpf ,then i thought id do the injector seals as you read so much about them ,the head is worn in the injector bores ,which i think is the problem .
But mind is made up ive hung the keys up and its ready for ebay .T:
