So people of T4's
I have blanked my EGR yesterday and cleaned my inlet out, messy job !!! However I have removed 2 nuts two get the inlet off and also two too get the EGR off the top end of the inlet. However should these nuts be tightened up to a specific talk (probably spelt wrong but in other words how tight should my nuts be in newtons?)
Cheers everyone
VW T4 1999 1.9TD
Jonty
No published torque setting that I can find ????
Just nipped up tight will do.......you'll soon know if they're not tight enough as it will blow exhaust gas out.
15 lb/ft or 20Nm seems to be used all over the engine for any thing being attached to the head in particular. Tensioners flanges and the likes. I think all the sump bolts are the same.
