Had a service done by my brother while i was on holiday and now it wont start!!! Tracked the problem down to the immoboliser as everything else is as it should be.
The engine simply turns and turns the fuel solonoid clicks as it should do, is there an easy fix for this problem without smashing off the immoboliser unit on the pump ( van is a 1997 1.9td) does it need to be pluged in to vag com to reset it or something?
Any advice would be great, im located in worthing west sussex if you know of anyone that can sort this problem out asap as need the van for work.
Thanks, liam :ILU:
