1 - 10 of 10 Posts
As title says both of these have stopped working the other day,anyone any ideas????
99 2.5 tdi 88bhpT:
Fuse 16 is indicators, also does glove box light. Does that work? Indicator relay is in the hazard switch, do they work when this is pressed?
Washer pump should be fed from wiper circuit, do they work? If yes then take a look at the pump, it's in the front of the washer bottle. Does the pump run at all? What about for rear wipers, it's a dual pump
Will have to check the glovebox light and get back to you,hazards don't work
Both front and rear wiper work fine,front and rear washers don't work...
If hazards don't work then it could be hazard switch which is the relay for indicators.
If no front or rear washers then either pump is goosed and no power to it.
Fuse 16 is fine mate,no good with electrics think I'm going to have to go to someone who does no haha,thanks for your replies though mate
1 - 10 of 10 Posts
