I think I may need a new set of injectors as I'm getting just a little black smoke when I rev up. I have a 1.9TD ABL engine so I just wanted to ask what are the best injectors that I can fit and where is the best place to get them?
I'll probably do the glow plugs at the same time so again, is there any choice here?
thanks
:ILU:
it might not be the injectors.
True, it might not but then it's a good place to start. I just need to know what other members have used in the past and got the best results. The bus has done a few miles now and I've no idea when or if they've ever been changed so it seems like a good idea to keep her running well. So any suggestions would be very much appreciated.
:ILU:
You've used these and they are the business?
Problem is that they look to be in the US which could mean nasty import duty! would prefer to find a UK supplier if possible
Thanks all the same - much appreciated
