Hello all
Have a lack of power issue with my van and checking suff out on here and vag-com, i've noticed a high percentage in my injector valve duty cycle timing is up around the 80% mark at idle....
is this normal?
cheers
Not if it is hot and the fuel temp is correct, duty cycle should be between 16-20% @ 80% the pump has no further electronic advance control.
Search the forum there must be hundreds of threads regarding vag-com timing settings.
