I’m about to glue insulation to my walls and ceiling and I noticed that there are some sort of thin insulation/soundproofing pads already stuck to the walls (see pic).
From what I’ve read, it’s preferable that the insulation (in my case cork panels) should be snug up against the surface. This wouldn’t be the case if I glue my insulation panels on top of the current walls because the stuff on there is smaller that the insulation panels I’m going to put on.
Would you recommend removing the stuff that’s in the wall now before I glue my cork panels on? Or just glue it on top of the stuff there now?
