1 - 20 of 483 Posts
07415125940
Well guys,
Heres one for you with the 88 bhp Blue I AJT code engine.
The IC from a mitsi L200 fits in the place of the original VW one !
Its fatter and has a larger core and is cheap as chis from a scrappy near you.
http://cgi.ebay.co.uk/MITSUBISHI-L200-2004-2-5TD-INTERCOOLER-WITH-FAN_W0QQitemZ270454983956QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item3ef85f8d14&_trksid=p3286.c0.m14
Even comes with a fan for that heat soak feelin ;)
You use the stock pipe for the sensor and some of the mitsi pipe too. Might need a bend or two but is a doddle.
And the front bracket from the 102, couple of 90 degree metal strips for the rear bracket. Fan not essential !
Pic to follow soon.
Ron.
IS this to fit on to top of IM or in front of the radiator as most IC mod`s do?
Looks good though
T:
I'm in, just bought one from your ebay link. thanks for the heads up. Just the fitting now, I know i should search but any one with the VW part numbers for the bracket and ducting??
Dave
07415125940
Some one will have that info,
I just saw a friend of mine at his workshop and he was most proud to tell me about it.
Recconend he could really feel the difference.
I've been thinking about some sort of fan on top of my Allard intercooler for a while (mainly from fiddling around in my PC and seeing heatsinks with fans on). I guess this is proof that a fan blowing cool air into the intercooler instead of just hot air coming off the engine is a good idea. :ILU:
Now to find a slim fan that I can wire in to the ignition. T:
I've got a 1.9td i've seen others on here fit the standard intercooler. I'm going to totally remove the EGR valve and rotate the inlet by 180. See Jimmyjames photos he mounted a VW intercooler on home made brackets.
I've had a search around on here but cant find the VW part numbers for braket and ducting.
Dave
Part number for the bonnet duct on a short nose is 701-145-843-A can have a look for the other numbers when I get home.
07415125940
Discussion Starter #12
Another vies of the stock mitsi IC
As you can see there is a fan. Dont know if it fits but if it does, well one can hook it up to the fans and have it come on when the engine gets hot ...
Interesting!
If there is room for the fan under the bonnet.....
Wonder if the shroud around the fan keeps a lot of the natural airflow away.....was it meant to run all the time?
Could this be a good alternative to the standard version as it doesn't have plastic sides to melt if used in conjunction with a hybrid turbo?
07415125940
Discussion Starter #14
Interesting!
Another thing I was thinking.
Well said.
I think I might have to go get one and do a how too on this.
1 - 20 of 483 Posts
