Hi guys,
Im about to fit LED downlights in the rear headilning of my van and was thinking of using the existing hardboard and covering it in the megavan mats headlining material they supply. once the LED lights are installed I will no longer want the existing rear lights that are in there so my question is...
If i remove the headlining, disconnect the existing light fittings but leave the wiring in place tucked away behind the hardboard panelling will this cause any problems?
Thanks,
Matt
No not at all , we used the existing wiring to run the roof LEDs , they very little power and you still have the courtesy light feature
